Should Replay Gain work when using 'Arrange Audio'?
  • Maxpower
    • Aug 2015
    • 68
    Hi - I searched the forums and read the help files but couldn't find an answer.
    If I use the 'Arrange Audio' feature of Music Converter . . . should I expect the Replay Gain DSP to work? (not the 'RG Apply' codec)
    I am finding it does not but just wanted to confirm before I start chasing my tail looking for other problems.
    Thanks!
    Re: Should Replay Gain work when using 'Arrange Audio'?
    No it will not work, as the audio is not being read.
    • Maxpower
      • Aug 2015
      • 68
      Thanks Spoon. I'll use the batch converter to fix the orphan files I have and apply the RG DSP directly.
