conversion help
    conversion help
    1....when i use the settings for the lame conversion as follows :
    channels : as source bit rate : vbr 192-256 frequency : as source
    then why the hell i get the output as "joint stereo "
    because the default channel for audio cd is stereo mode i think ?
    2. what is the option " Disable Bit Reservoir " under variable bit rate
    options means ? what is the need of bits like private , original ?
    Re: conversion help
    It defaults to joint stereo, because I have heard compelling arguments that even at high bit rates - joint stereo can give higher quality then stereo (more bits to encode with).
    >2
    Don't really know about those options apart from Original, any Sony product doesn't seem to import any mp3 unless original is set.
