Problem After Installation
  • bwriter
    • May 2026
    message:
    After I installed the registered of dBpoweramp, I clicked on CD Ripper and received a message from Norton 365 Deluxe. Here is what was in the Norton 360 Deluxe moved Ogg Vorbis.dll to Quarantine because it was infected with Win64:MalwareX-gen[drp]. It wasremoved from C:\Program Files\dBpoweramp\encoder..
    Is there a problem with the dll file or is it a problem that you need to inform Norton that it has a false Positive. I can restore the file with an exclusion (possibly) since Norton wants to delete the file from my Windows 11 Pro PC. What do I do?
    I am a blind user and I am not sure if I posted this topic in the correct place.T hank You.
    • 46167
    See last message:
    The following lists security software which is not performing as it should, that is blocking legitimate programs (such as dBpoweramp) from running. There is nothing we can do on our side, we produce legitimate software, virus free for the last 20 years, never once have we supplied a virus, Trojan, spyware with any of our
