dMC Audio CD Input not working
  • Shawn Harvey
    Hi. I have a registered copy of "dBpowerAMPCDWriter-Registered", as it's listed in the name of an install file I have on my computer. I forget
    whether I bought the Audio Amp and CD Input together or separately, but I'll include some information at the bottom of this email so you can
    look me up in your system.
    Anyway, my problem is that the "dMC Audio CD Input" program, when
    launched, goes to the beginning screen and then just sits there, doing
    nothing and allowing no input. As a matter of fact, I usually have to go
    into my Task Manager to kill the program. Strangely, the "dBpowerAMP
    Music Converter" program seems to be running fine.
    I've tried unloading and reloading the program several times but no
    luck.
    Any help you can offer is appreciated.
    Shawn Harvey
    Here are my specs:
    Computer: Gateway 1.8 GHz, 512RAM, 80 Gig HD, Windows XP Home, DVD
    Player and 48X CD Read/Writer.
    Install File: dBpowerAMPCDWriter-Registered.exe, 2.36 MB, Created
    Friday, Oct. 3, 2003
    I most likely charged the initial fee on my Visa.
    Thanks!
    Re: dMC Audio CD Input not working
    Try the latest version of dMC from the Beta section of this forum, if you still have problems post back here.
    • kcowan
      • May 2006
      I also registered on another computer:
      and would have paid with a Mastercard
        Spoon recommended to download and install the latest version of dMC.
        Install it on top of the one you have so that you don't lose the registered status.
        Make sure you install to the same location as before, and using an administrator account.
