Auto-Populate Track Number and Total Tracks tags
  • pjn
    • Jan 2026
    This might already be possible using the [ID Tag Update] converter, but I'm not smart enough to figure it out!
    When adding tags to my FLAC files, the vast majority can be populated once at the Album level via "All Files" in the Tag Editor.
    Once I've entered the Artist, Album, Year, Genre, Release Type and Disc (e.g. Disc "1/1") in one go at the Album level, I then need to enter the Track Name, Track Number and Track Count at the individual track level. To save a little bit of time, could an option be added to populate Track Number and Track Count for all selected files?
    e.g. If I select 20 files in Mac OS Finder and then "Edit Tags with dBpoweramp", can I click a menu option to enter "1/20", "2/20"...."20/20" into the Track tag for each file, in the alphabetical order they appear in the Finder?
    I have experimented with the [ID Tag Update] converter, but I can't figure out how to get it to only populate the Track Number/Track Count tag, how to calculate the Track Count, and how to parse it all when file naming conventions for the files are inconsistent depending on where I've purchased the album from (usually Bandcamp, occasionally Qobuz).
    No worries if this isn't possible - just wanted to throw the idea out there in case anyone else would also find it useful?
    You could enter /20 at the album level, then simply add the track numbers as you cycle the tracks. Normally with tag editing we cannot be 100% certain of the order
    • pjn
      • Jan 2026
      Thank for the response. Yeah, it's slightly quicker to pre-enter the /20 at the album level, but after entering the track name it's still 2 tab key (or down arrow) presses, followed by a left arrow press to move cursor to before the /20, then entering the track number.
      I was hoping for something like MP3Tag's automatic track number / track count menu option that's a 2-click solution which works flawlessly.
      No worries - I'll continue to use MP3Tag for that part of my workflow - it's not the end of the world.
      (Now Peter has re-instated the next/previous track keyboard shortcut in the latest dBpoweramp beta, my workflow is already much faster than it was previously)
