Hi-Res Audio to 16-bit/44.1kHZ with ARDFTSRC
  • davidi
    • Nov 2016
    • 19
    Hello, I am looking for some guidance/best practice on using the new ARDFTSRC resampler when converting Hi-Res audio to 16-bit/44.1kHZ. Are these settings still best practice? Any help would be greatly appreciated.
    Example A
    Source FLAC: 24-bit/44.1kHz
    DSP Effects:
    Bit Depth (Fixed: 16 Bit, with triangular dither)
    Example B
    Source FLAC: 24-bit/48.0kHz or higher
    DSP Effects:
    Bit Depth (Fixed: 32 Bit float, no dither) <---------- should I change this to 64 Bit IEEE Float or 32 Bit IEEE Float?
    Resample (Resample to Frequency: 44100; SRC Quality: Insane) <------- Is Insane quality worth it or will High or default suffice?
    Bit Depth (Fixed: 16 Bit, with triangular dither)​
    Bit Depth (Fixed: 64 Bit float, no dither)
    Resample (Resample to Frequency: 44100; SRC Quality: High)
    • davidi
      • Nov 2016
      • 19
      Perfect, thank you!
