dbpoweramp onWindows 11: turn to 64 bit
  • hopalong
    • May 2007
    • 40
    How can I turn dbpoweramp to 64 bit, retaining my 32 bit settings on Windows 11 ?
    Is a step by step guide available?
    Uninstall dBpoweramp fully, install the 64 bit version and most settings should be preserved.
    • hopalong
      • May 2007
      • 40
      How can I Uninstall dBpoweramp fully?
      I found these possibilities to uninstall:
      Uninstall from Apps - Installed Apps
      or
      Uninstall from Control Panel\Programs\Programs and Features,
      one by one each dBpoweramp component (I have 16 listed)
      or
      run C:\Program Files (x86)\SpoonUninstall\SpoonUninstall.exe
      The SpoonUninstall folder contains 12 codec .dat files and 6 .exe files in addition to SpoonUninstall.exe
      Previously I installed dBRefMusic-2025-07-21==C1D0861C=ADA14604.exe
        • 1932
        Do you actually run dbpa in 32bit at all? Did you force the installation process to setup the 32bit version previously?
        • hopalong
          • May 2007
          • 40
          Yes, I use it for music files, normalize, convert mostly.
          What is the purpose of your question?
          I wouldn't pay for it if I didn't use it.
            • 1932
            The standard installation has setup a 64 bit version for years already. There have been only a few scenarios where a 32 bit setup were recommended or necessary.
            • hopalong
              • May 2007
              • 40
              My first dBpoweramp version was Power Pack & Mp3 Encoder, which I bought in 2005, and it was 32-bit.
              Then, after a while, a 64-bit version became available, and I found a note in my records from 2014 about the dual installer, right shift for installing the 32-bit version.
              This has now been discontinued with the 2025-11-12 version.
              I didn't switch to the 64-bit version because the 32-bit version suited me perfectly, and I wanted to avoid the transition tasks, which I still don't have enough/accurate knowledge about.
              In any case, I'm still waiting to see if anyone can provide more specific information on "How can I uninstall dBpoweramp fully?"
                See:
                Invert the 3 check boxes to just remove from program files
                • hopalong
                  • May 2007
                  • 40
                  Thank you, works fine!
                  • hopalong
                    • May 2007
                    • 40
                    As I already posted, the switch to 64 bit was successful.
