Advice please for multi-core CLI conversion under MAKE
  • chrisjj
    • Nov 2008
    • 300
    Can anyone suggest the best way to get CoreConverter.exe to use all the CPU cores when run from a MAKE utility?
    I am planning to convert a manual Batch Converter procedure to an automatic procedure using the MAKE utility calling CoreConverter to convert files that have changed since the last conversion, but I can see no way to drive the -processor="n" parameter such that all cores are used.
    This will run under Windows 7.
    Re: Advice please for multi-core CLI conversion under MAKE
    You have to run multiple core converters, to use multiple cores.
    • chrisjj
      • Nov 2008
      • 300
      OK, thanks. So MAKE must generate e.g.
      CoreConverter.exe -infile=1.wma -outfile=1 -processor="0" -convert_to="Wave"
      CoreConverter.exe -infile=2.wma -outfile=2 -processor="1" -convert_to="Wave""Wave"
      from a single rule. Anyone know how to get MAKE to generate that automatically varying -processor value?
