HELP!!! Info PopUp does not appear
  • junky
    • May 2002
    I tried everything to get the info popup in windows explorer shown, but it doesn't work! I tried it via dmc configuration an rebooted -> nothing! Also I tried to disable it -> rebooting -> nothing! I doesn't work, but i hardly need this function! Please help, where is the information about showing infopopup or not written into registry or somewhere!
    PS: I tried the Release 8 and all the newer BETA Releases, it wont work!!!
    Thx
  • junky
    • May 2002
    found it -> my mistake!!!
    allright it works now!
      Hey how did you fix it? I have WinME & mine is not working all so.
        Re: HELP!!! Info PopUp does not appear
        i also have the same problem after upgrading from ver. 9 to 10.1. am using win me.
        popup tags stopped displaying. tried re-installing and toggeling off the tag option in congiguration.
        please help.
          Try holding over other audio files, such as wave, does it show?
          • series800
            • Nov 2003
            Im having the same problem! i must know how you fixed it!! please help!
            • series800
              • Nov 2003
              possible solution
              Ok i think i figured it out: (for WinXP, ME and 2K) Go to My Computer, click the Tools menu, go to Folder Options, then click on the View tab. Go to the bottom of the list and you should see an option that says "Show pop-up description for folder and desktop items". Make sure it's checked. Click Apply and then click OK. The tag info should pop-up now when you move your cursor over a file. (this worked for me btw)
