Two questions: Right Click on OS X + DSP effects: Noise Removal
  • flips
    • Jan 2006
    • 93
    Two questions:
    1. Would/could/should it be possible to right click sound files in Finder (OS X) and select Convert with dBPowerAmp?
    2. Is there a DSP effect I could just to trim away noise (or do I need wavelab or some other app)?
    flips
  • BrodyBoy
    • Sep 2011
    • 780
    Re: Two questions: Right Click on OS X + DSP effects: Noise Removal
    Originally posted by flips
    Two questions:
    flips
    Don't know about Finder integration in OSX, but as to your *2 question....that's definitely work for an audio editor, which dBp isn't.
    • flips
      • Jan 2006
      • 93
      It should be possible to automate for non-interactive use. (NCH's WavePad has an automatic algorithm that works pretty well.)
      I take it this is not available in dBPowerAmp, then ...
        • 46139
        1. Right click >> Services >> Convert with dBpoweramp
        • flips
          • Jan 2006
          • 93
          Ah, and also edit tags, great!
          • moonloop
            • Oct 2009
            Is the plugin ' Write Meridian XML files available ?
            ~M~
              • 46139
              Not for OS X no.
              • MacTan
                • Mar 2013
                Is the Meridian Plugin planned?
                -P-
                  • 46139
                  Sorry it is not.
