Problem with utility codecs
  • keithbaran
    • Feb 2004
    • 37
    Hello all,
    I just switched from Win XP to Win 7 64 bit. I have updated Music converter to V15 and all codecs. I use to be able to right click on a music file, select " convert to" at which time I could, from a drop down menu, select several choices such as "wave", "mp3", "Flac" etc. including utility codecs such as " arrange audio", "tag from file name" etc. Since the switch to Win 7 64 bit no utility codecs appear in the drop down menu when I right click on a music file and choose " convert to".
    I have re-installed the current utility codecs several times with no luck. I apologize if this is answered somewhere in the forums, but I cannot find an answer. Any assistance would be appreciated
    Regards
    Keith Baran
    • 46043
    Re: Problem with utility codecs
    You must have 32 bit dBpoweramp still installed, see:
    http://forum.dbpoweramp.com/showthre...401*post143401
    • keithbaran
      • Feb 2004
      • 37
      Thank you Spoon, I did uninstall the old version first but just deleting that file did the trick. As always, you, this product, and company are the best, Rock On!!
      On a side note any updates on a release of the new dAP?
        • 46043
        We are going a totally different direction for dAP...
