AIFF to ACC Conversion Problem
  • gswaul
    I just finished converting my library over to ACC for use on my iPod. All went very well with a few exceptions. Several of the files showed errors and 0 bytes in their respective folders. I have deleted them and tried multiple times to convert them with no success. I even tried to convert to a different codec just to see if I could get around this problem, no luck. Does anyone have a solution or suggestion? Thanks!
    Re: AIFF to ACC Conversion Problem
    So if you convert the problem files to wave, the wave files are 0 bytes also?
    • gswaul
      All attempts to convert get "file error reading chunk". The original attempt gave me the 0 bytes result, now no conversion results other than this message.
        It is likely that the aiff files are corrupted, can itunes play them?
        • gswaul
          Both iTunes and JRiver have no problem playing the original files.
            Are you running R15? I am sure this was updated in R15.
            • gswaul
              Whatever the problem was, I resolved it by starting the whole process over for those files. I still received some error messages but the files did copy this time. In some cases, a converted file was missing tag information even though the rest of the folder was fine. Strange . . . .
