Hey Guys,
I'm about to have a nervoud breakdown trying to do what would seem to be a simple task!
I have a folder calleds WAVS, naturally in it are lots of WAV files. I need to convert these to MP3 and stick them in a folder called, you guessed it, MP3.
New wavs get added daily to the folder so I need it to be watched, and when a new one goes in, convert it and drop it into the MP3 folder.
Sounds simple right?!
Wrong.
My main problem is the original file keeps getting deleted. Surely there is a way to tell the ACE to leave the source file alone?
I thought a workaround would be setting the 'PROCESSED' folder as the 'WATCH' folder, but instead ACE just has a complete sizure and starts deleteing EVERYTHING - and it can't be stopped. You gotta CTRL - ALT - DEL to kill the process before it wipes away everything.
Is there any documentation to do with ACE?
Wrong.
