dMC Audio CD Input - unable to load WNASPI32.DLL
  • Paultx
    • Aug 2003
    • 8
    When I opened dMC Audio CD Input the first time after installation it gave me that message. Any idea on how can I fix that? Thanx in advance.
  • RossRoy
    • May 2003
    • 403
    What version of Windows are you using?
    • Paultx
      • Aug 2003
      • 8
      Windows 98 SE
      • RossRoy
        • May 2003
        • 403
        It is probably ASPI that is not installed correctly.
        Go to this page and scroll down to the "Windows 95/98 Specifics (ASPI)" and follow the instructions there.
        Should you still have a problem, please post again.
        • Paultx
          • Aug 2003
          • 8
          I did everything you suggested and the error message is now gone. But if I insert an audio CD it won't show its contents in the dMC Audio CD Input window, no matter how many times I hit the Refresh button or try to reload the CD drive. N.B: if I close de CD drive tray with the CD I want to rip inside and don't keep the Shift key pressed, Winamp, which is associated to audio CDs, opens normally and starts to play the songs -and using the cddb feature to show tracks names.
          • RossRoy
            • May 2003
            • 403
            Try reinstalling Music Converter. If that doesn't work, I'm afraid I can't be of more help, you will need the help of Razgo or Spoon.
            As for Winamp opening to read the CD upon insertion, you could always disable auto-insert notification, but I think the latest DMC beta (release 10 beta 8) does that automatically while it is running.
              Try the 'Options' button and make sure the right CD drive is selected.
