Problems with wav IMA ADPCM 22.050 kHz 4 bit Stereo converter
  • Eetheart
    • Dec 2013
    As the title says, I am trying to convert from .mp3 to compressed .wav using the format IMA ADPCM with 22.050kHz, 4 bit stereo.
    After converting the files, I noticed that the files are unusually small in size. Also, the play-time on the files is 0:00.
    Any idea how to make it work?
    • 46228
    Re: Problems with wav IMA ADPCM 22.050 kHz 4 bit Stereo converter
    Try using DSP effects to match the sample rate, so use Resample set to 22050 Hz
    • Eetheart
      • Dec 2013
      Tried using Resampler. Still wouldn't work :/
      • Eetheart
        • Dec 2013
        Tried uncompressed with Resample. It worked for the project! Thanks, a lot!
