WMA codec problem
  • johnrsellers
    • May 2003
    • 9
    WMA codec problem
    Every time I try to install the WMA9 codec for dMC, I get an "Entry Point Not Found Error."
    • 46171
    See here:
    http://forum.dbpoweramp.com/showthread.php?t=1971
      Re: WMA codec problem
      John,
      did this work,
      Cheers,
      Grom...
        • 46171
        Should have done, make sure you reboot after installing.
          hi, tried to convert wma9 to mp3(lame) with the alt preset standard, how come after the conversion, the resulting mp3 was at a 128kbps bitrate?
          thanks.
            thanks.
            oops... sori 'bout that, it was just that the first part of the song was really constant... but when the song pumped up, so did the bitrate..
            my apologies.
            nice piece of sotware man! :-)
            • johnrsellers
              • May 2003
              • 9
              Installed WMP9...problem solved.
              Sorry about the late response.
