Best quality when converting 24-bit 96khz FLAC to regular or 16-bit 44,1 wav for CD
  • dayter
    • Jun 2013
    What is the best possible setting for this conversion? Must I use a DSP like bit-depth and which setting for dithering?
    • 46229
    Re: Best quality when converting 24-bit 96khz FLAC to regular or 16-bit 44,1 wav for
    Use the DSP effect:
    Resample (44.1khz)
    Bit depth 16 bit (with TDPF dither)
    • dayter
      • Jun 2013
      Use the DSP effect:
      Resample (44.1khz)
      Seems that this works fine, conversion speed goes down from over 35 (without DSP) to now 6x!
      Must I set exact this order, first bit depth and then resample?
      And what about the settings im the main window under converting to - uncompressed: i chosed 16bit CD and 44.1khz, together with the settings you told me for the 2 DSP?!
        • 46229
        For best quality use that order yes. It is slower because we use a high quality resampler which has to do lots of work behind the scenes.
        For the wave page use [as source] for all the options and uncompressed.
