Batch Converter does not work over network
  • rwoofer
    • Apr 2013
    I'm trying to use the Batch Converter to convert files on my NAS.
    If I click on the "+" by network I get the error "dBpoweramp Batch Converter has stopped working" and all I can do is close the program. Alternatively if I click the checkbox by network I get the message "Only folders within a network can be set for inclusion", which makes sense, but the only way you can select folders is to click on the "+".
    I'm running Win 8 64 bit and a Synology NAS.
    Thoughts from anyone?
    Re: Batch Converter does not work over network
    Try mapping the network share as a drive letter (right click on share in File Explorer >> Map network drive...)
    • rwoofer
      • Apr 2013
      Thanks, nice workaround that worked.
      Also suggests my experience above must be a bug otherwise why would the network "+" and checkbox be offered.
        Yes will make a note to test (it is perhaps something specific to Windows 8)
