MusicConverter has encountered a problem ...
  • Tomos
    • Aug 2003
    Conversion mp3 to wav crashes (allways). Istallation is new, OS W_XP Pro., DBpowerAMP installed too.
    Colateral effect - even if I define the same folder as for input file, it allways creates new empty directory with the same name. Any hints for help?
    thanks
    The player? can you play that mp3 file?
    • Tomos
      • Aug 2003
      Yes, no problem.
        Which version of dMC do you have? I found a crashing bug in the newest beta version today.
        • Tomos
          • Aug 2003
          Release information
          dMC: Rel 9a
          PowerPack: Rel 3 (but did chash also without it, the same effect has been observed
          MS Windows XP Prof. Version 2002, SP 1
          Hope this helps!
          Thanks and regards
            Is it any mp3 file, or just that one, does it crash at the beginning or end?
            • Tomos
              • Aug 2003
              A perfect hit!
              I was allways trying to convert the files from one new collection of mp3's and it crashed allways at the very begining. Now I've tried with several mp3's from other (older) collections and every time it converted perfectly. Maybe some mp3's have a kind of protection or similar (I have to investigate further) ?
              Anyhow, dMC works OK. Thanks for your help.
