Problem Ripping directly to AIFF Format
  • Patatorz
    • Feb 2013
    • 12
    Hello everybody,
    I just tried to rip with the latest DbPoweramp few cds (at least 3) directly into Aiff format. Everything is fine but when I want to edit the informations with another software (Tag&Rename) I have some errors (stream Error reading) on some files and it is impossible to edit.
    If I rip to wave and convert after to Aiff => no problem.
    Do you have this problem before and any solution.
    Best regards
    Re: Problem Ripping directly to AIFF Format
    You need R14.4 (beta) to correct AIFF tagging issues. It is in the beta section of this forum.
    • Patatorz
      • Feb 2013
      • 12
      Thanks a lot I'm going to have a look.
      BR
      • Patatorz
        • Feb 2013
        • 12
        Just tried : works perfectly !!!
