24 bit to 16 bit conversion??
  • breton15
    • Jan 2013
    I'm new to converting. I just bought a 24bit flac file and want to convert it to 16 bit. I converted at default level 5, but after conversion, the files were the same size, should I be using a lower level??
    Re: 24 bit to 16 bit conversion??
    You need to include the DSP effect 'Bit depth' set to 16 bit, otherwise the FLAC files you create are 24 bit the same as the source.
