Noise / static between tracks on usb
  • JakeChambers
    • Dec 2012
    If I convert flac files to wav and put them on a usb flash drive, I get a second of noise or static between the tracks. Anyone know how to fix that?
    • 6187
    Re: Noise / static between tracks on usb
    I've read here that certain players don't like tags in WAV files and this creats the noise at the beginning of tracks. Try removing the metadata tags in the WAV file.
      • 46167
      Yes your player has broken WAVE decoding support, as it is playing the tags as audio.
      Open dBpoweramp Configuration >> Codecs >> Advanced and set the WAVE tagging to none.
      • JakeChambers
        • Dec 2012
        Thank you. I removed the tags and it worked. That is about the last thing I would have thought of.
          • 46167
          Out of interest, what is the player?
          • JakeChambers
            • Dec 2012
            It is a cheap sony blu-ray player I have in my bedroom. BDP-S390
