R14.3 won't read "Initial Key" in ID tags
  • Phreak
    • Nov 2012
    This is a weird one, might be a bug...
    I use Mixed In Key software to read & write the tempo & key of my mp3 files in the ID tags.
    When using version R14.2, it would read the 'Initial Key' & 'Tempo' data of all of my mp3 files.
    With R14.3, it now only reads the 'Tempo' data and does not pick up on the 'Initial Key' data at all.
    Yes, I've checked all the settings re ID tag options within dMC.
    If this is a version bug, how can I report it?
  • Bacchu
    • Nov 2012
    Re: R14.3 won't read "Initial Key" in ID tags
    then simply create it in "EDIT ID TAG"
    • Phreak
      • Nov 2012
      Not exactly.
      The specific data is already embedded in the mp3 files, this piece of software is supposed read the metadata and display it in the 'tooltip' like it did in previous versions before.
        The next R14.4 beta update will fix this.
        • Phreak
          • Nov 2012
          Awesome. Thanks for the head's up!
