No audio files selected for conversion error
  • smcg
    • Oct 2012
    • 16
    When running the batch convertor or regular convertor, neither program can see any files in any folders - local drives, mapped drives and UNC paths. I've set the filter to include all types and the files themselves are flac or wav.
    Anyone have any ideas?
    • 46171
    Re: No audio files selected for conversion error
    Security software blocking the program?
    • smcg
      • Oct 2012
      • 16
      turned off has the same result.
        • 46171
        If you right click on one of your audio files, do you get convert to on the menu?
        • smcg
          • Oct 2012
          • 16
          Working now, maybe the hurrican helped. Thanks for your replies.
