Batch conversion problem, Please help.
  • excasanut
    • May 2012
    I just converted my entire library from ALAC and AAC recordings to FLAC and forgot to delete source file so no everything is double.
    Deleting all doubles manually for 2000 song+ will be a little too time consuming so I am looking for a quicker solution, any suggestions please?
    I am using itunes and plan on switching to Jriver at some point but that is step 2. I need flac because my media player does not read ALAC files.
    There is an other issue, when I deleted one ALAC file manually , itunes cannot locate the new flac file, even when I click on it. Any suggestions please?
    Thank you.
    • 46228
    Re: Batch conversion problem, Please help.
    Firstly I would not convert aac to FLAC (you are converting lossy to lossless), you end up with the same lossy file which takes up 5x more space.
    You can search in Windows explorer for *.m4a and delete that way.
    • Porcus
      • Feb 2007
      • 792
      As Spoon says, it is quite nonsensical to convert AAC to FLAC.
      Are you sure you have not deleted the originals? You can delete the FLACs and start over. Then do only convert the ALAC's.
      Stop using iTunes? Apple – like Microsoft – tries to lock out competition. Seems you have to choose between iTunes and your media player which reads FLAC but not ALAC.
      My media player of choice is foobar2000. It plays ALAC out of the box. If you want something simpler, then maybe the Boom player from the same author, is updated to handle ALAC too. http://perkele.cc/software/boom
