ogg not converting & ogg auTuV SSE3 not transferring tags
  • IAmLostForWords
    • May 2012
    Hello there,
    since recently, source files (mostly flac 24/96, but also 16/41) won't be converted anymore to ogg using the standard ogg encoder. Short before finishing it stalls, then crashes without notice and leaves both an unfinished ogg as well as an accompanying tmp file.
    Additionally, when using the AuTUV version, the conversion actually happens but no ID tags get written. This applies to all files with more than one graphic stored (i.e. cover, back & disc)
    This does not cause issues with i.e. lame
    • 46370
    Re: ogg not converting & ogg auTuV SSE3 not transferring tags
    Try a clear and reinstall:
    • IAmLostForWords
      • May 2012
      Thanks for the quick response. Unfortunately this does not help. It is consistently appearing as soon as there is more than one picture embedded in the tags (using foobar2000, mp3tag for tagging. flac -t does not show any error on the sources): converting to any other format than ogg works like charm, it is only related to the standard ogg-encoder that crashes when tagging.
        • 46370
        Possible bug noted
