Need help converting 24/96 files down to 16/44 files
  • b8375629
    • May 2006
    • 73
    Ok, I just bought the R14 Reference Edition and would like to know how to convert 24/96 WAV files down to 16/44 files without clipping.
    Can anybody here help me with the settings I need to use in order to do this? :blush:
    • 46231
    Re: Need help converting 24/96 files down to 16/44 files
    Use the DSP Effect 'Resample' and Bitdepth set to 16 bit
    There will be no clipping going 24 bit >> 16 bit as the bottom 8 bits are dropped.
    • b8375629
      • May 2006
      • 73
      Two questions:
      So set the Resample to 44100 and set the bitdepth to 16 bit, right?
      What about dither?
        • 46231
        You can dither if you wish, there is the ability to retain more information when going 24 bit >> 16 bit.
        • b8375629
          • May 2006
          • 73
          I'm not sure what you mean.
            • 46231
            In the DSP Effect 'Bitdepth' is a dither option, it is best this is checked for triangular dither when going 24 bit >> 16 bit
            • b8375629
              • May 2006
              • 73
              Hey thanks for the response.
              What does triangular dither do?
              As opposed to "rectangle dither" or setting it to "none"?
                • 46231
                You would have to research this subject in google if you are interested, a one paragraph reply would probably not give a sufficient answer.
                Search for TPDF dither
