Need help with large flac to mp3 conversion!
  • jasong
    • Dec 2011
    I am trying to convert about 365 gigs of flac files to mp3's. I would like to retain the files in the original folders instead of converting them all into
    individual files. I searched for how to do this and have found people have asked the same question as me. I know that I must use dynamic naming and type this--- [origpath]\[origfilename] , but I am unable to click Dynamic under Output Location because the text is grey and not black. I can click
    on Original Folder and Folder but not Dynamic. Any help as to what I am doing wrong would be great! Also, once I am able to click dynamic, should I
    type [origpath]\[origfilename] or Mp3/[origpath]\[origfilename]. Also converting flac to mp3 240 kbps said it would take 3 days and a number of
    hours, would converting to "standard" 190 save me some time? Thanks for all your help!
    Jason
  • Wayne
    • Aug 2002
    • 1254
    Re: Need help with large flac to mp3 conversion!
    Which version of dBpowerAMP do you have? Only the Reference version allows you to use the dynamic naming.
    • jasong
      • Dec 2011
      Ok. I purchased the reference. Now what should I type under dynamic to keep the files the exact same way they are now? I am also curious as to why the program keeps crashing giving me a "not responding" message? Thanks!
      • jasong
        • Dec 2011
        Ok, I got everything to work the way I want it. Is it possible for the converter to transfer my album art with each album to the new location. I noticed the folder.jpgs are missing from the new conversions?
          • 45448
          There is a DSP effect 'Preserve Album Art', include it.
          • jasong
            • Dec 2011
            Found it. Thanks a lot!!!
            • JellyCat
              • Jan 2012
              I'm doing the same thing but I'm stuck - how do you do it ? I have the Reference version and wish to convert Flac to MP3 and send the files to an external HD in their relevant folders. I can do one at a time but not a batch, please help.
                • 45448
                There is a program Batch Converter, the help file describes how to use it.
                • JellyCat
                  • Jan 2012
                  Yes, found it. Thanks Spoon. Actually the answer is in the first post - maybe I should have read it properly. I've had this software for years too but never actually needed to use the batch converter to convert so many files until now.
