Problems Converting MP3 to AAC Format
  • Brian104
    • Aug 2011
    I am a new user and need help. I am trying to convert an MP3 file to an AAC file. I thought that I had gone through the process of downloading and installing the NERO AAC encoder files, but when I click the MP3 file I want to convert, I immediately and get a message warning me that “a separate encode must first be installed”. Then when I try to encode, I just end up with an empty file in the specified directory. When I click on the “encoder” button it says “no encoder specified” and when I click to locate encoder, nothing appears in the menu structures it defaults to. I went ahead and copied the “codecs” section of the configuration file to clipboard, and pasted the results below (looks to me like all codecs are installed, but I might be reading it incorrectly). If someone would please let me know what I am doing wrong and what I need to do to get it to work I would really appreciate your help. Thanks!
    Codecs Installed
    Encoders (write)
    [aac to m4a]
    .m4a
    [m4a Optimize]
    [m4a to aac]
    .aac
    [Multi Encoder] Release 4
    AAC (Advanced Audio Compression)
    .aac
    Aiff Release 11
    .aif
    Apple Lossless Release 14
    .m4a
    FLAC Release 14 (FLAC 1.2.1)
    .flac
    m4a Nero (AAC) Release 10
    .m4a
    m4b (Audio Book)
    .m4b
    mp3 (Lame) Lame 3.98.4
    .mp3
    Test Conversion
    Wave Release 14.2
    .wav
    Windows Media Audio 10 Release 7 (WMA Pro 10)
    .wma
    Decoders (read)
    Advanced Audio Compression Decoder
    .aac
    Aiff Decoder
    .aif, .aifc, .aiff
    CD Decoder Release 14.2
    .cda
    FLAC Decoder
    .flac
    m4a / mp4 Decoder
    .m4a, .m4b, .mp4
    Monkeys Audio Decoder
    .ape
    mp3 Decoder Release 14.2
    .m2a, .mp1, .mp2, .mp3, .mpa, .mpeg, .mpg, .mpga, .mpx
    Wave Decoder Release 14.2
    .bwf, .wav
    WavPack Decoder
    .wv
    Windows Media Audio Decoder
    .asf, .asx, .wma, .wmv, .wvx
    Install on Demand
    Ogg Vorbis .ogg
    Real Audio (Helix) (read only) .ra
    Midi (read only) .mid
    Shorten (read only) .shn
    Musepack (read only) .mpc
    Re: Problems Converting MP3 to AAC Format
    After you install the Nero AAC encoder (from Codec Central) the help file shows where a 2nd component (from nero.com) must be downloaded and installed, you have done this also?
