Transfer of album art during conversion of FLAC to MP3 using CLI
    • 46230
    Re: Transfer of album art during conversion of FLAC to MP3 using CLI
    Yes I have
      • 46230
      • 1gumby
        • 9
        Thanks, I always assumed they were the same file type. My bad. Is there an easy way to covert the .jpeg extension to .jpg in windows?
          • 46230
          If you are good with command prompts, start >> run:
          cmd
          cd \
          cd (the location of the file)
          • pfeerick
            • May 2008
            • 15
            They are the same image type, just different extensions. Disable the 'hide extensions for known file types' option in Windows explorer (on windows 7 - organize, file and folder options, view tab), and then rename the file and change the extension to .jpg (instead of .jpeg)
            • 1gumby
              • 9
              #21
              Thanks! I really appreciate the assistance.
