problem with realplayer file conversion to mp3 not entire length..
    hey there. this program is really wonderful. however i ran into a problem. i have a long .ra file that only contains audio. i can start to covert it with the converter but then after aprox 40 minutes it finishes converting (as if everything is fine) however the file is way longer then only that. it also only converts those 40 minutes..
    so i am not sure whats up with that. does anybody know what my problem is?
    thanks! --------------KonstantinG
    The real audio file might have an error at 40 minutes that my convert is not able to correct.
      i see what you are saying, but after i chaged some paramiters for export(i changed to VBR) it stopped after34 minutes.
      any idea about whats going on, or do u still thing its an error in the file.
        Try converting it to wave.
