How can I have each track separated after conversion from flac to mp3
  • Sam71
    • Mar 2011
    Could someone please guide me as to how properly convert .flac file to .mp3?
    I have few flac files which I have converted to mp3 but the output becomes one large mp3 file while the flac file contains many tracks.
    How can I have each track separated after conversion from flac to mp3???
    • 46228
    Re: How can I have each track separated after conversion from flac to mp3
    You have a single flac file containing multiple tracks?
    • Sam71
      • Mar 2011
      1
      • Sam71
        • Mar 2011
        Thank you Spoon,
        Yes, but which of these should I use? I have used the dbpoweramp Music Converter but it makes a single .mp3. How can I have multiple tracks included in that???
        • annihilatorx
          • Feb 2009
          • 13
          You can only split the file if you have the cue sheet (a file with extension .cue).
          You can use a software called Medieval Cue Splitter to split the flac first, then convert to mp3, or convert the single flac to single mp3, then split with Cue Splitter.
          You have to manually use Notepad to edit cue sheet to make sure the line e.g. FILE "MUSIC.flac" WAVE, file name is correct
          • Sam71
            • Mar 2011
            Hi annihilatorx,
            Thank you for your recommendation. It worked perfect. My other question is:
            Do you know a good Cue Splitter and/or MP3 Splitter for Mac??
