Multi Encoder does not work! (dbpoweramp 14)
  • PiresMachine
    • Feb 2011
    Hi
    I recently installed the dbpoweramp v14 in a W7 x64 with a i7 640 Processor 2 Core(s) ,4 Logical Processor(s) and initially the multi-encoder didn't work. Then I reinstalled it "as administrator" and it works well (using the 4 processors), but for a few days, only.
    Now, for a unknown reason it stopped work again!..only one file is converted at a time. I made a clean uninstall and reinstall it a few times..used the DSP multi-cpu function..but..nothing worked.
    I'm trying to convert other lossless files to flac..but I already tried to mp3 and so on..changed the output folders..the problem still remains.
    need some help here please
    I've been using Dbpweramp since a long time ago (around 5 years).
    Thanks a lot
    • 46228
    Re: Multi Encoder does not work! (dbpoweramp 14)
    Are any error messages shown?
    • PiresMachine
      • Feb 2011
      Nothing appears.
      The program converts the files one by one...
        • 46228
        And if you try to convert 10 files, it stops (freezes after the first track?).
        • PiresMachine
          • Feb 2011
          No.
          The program converts all the files, one by one.
            • 46228
            Make sure you have dBpoweramp Reference (look in dBpoweramp Configuration), as this is required for Multi-CPU support.
            On Multi-encoder is an option on the first options page to use multi-cpu, the DSP effects 'CPU Force' have no effect on multi-encoder.
            • PiresMachine
              • Feb 2011
              Ok..that was the point.. I had the powerpack version -.-'
              Now everything is working fine again!
              THANKS a lot Spoon..5 stars to the support
              Keep on Rock!
