Problem with multi core - Wav -> Flac
  • SteelMan
    • Nov 2010
    Hi guys, Am using the program Dbpoweramp Batch Convertor.
    When I am processing the audio file, only 1 processor is working.
    How come? My comp have 4x processor. How can I set this?
    Change 1x, to 4x?
    Thx!
    Re: Problem with multi core - Wav -> Flac
    Use the DSP Effect Force Multi CPU, also you require the Reference version to do multi-core.
    • SteelMan
      • Nov 2010
      Hi. Thx
      Ok, I found it.
      I installed it, but its not working.
      And what about the version? I payd for this version, but i dnt know if is it the right one. U think its possible that some version, cnt not use this? even if u pay for it?
      On my version I have "release 14", and for this thing its just requre the 13. Why is not working?^^ I already forced all the 4 cpu
        See:
        • Jeffy912
          • Nov 2008
          I'm having the same issue with the multi-core not kicking in during file conversion (I mainly convert flac files to mp3).
          I'm quite confident that I have the reference version of dbpoweramp as multi-core used to work. It just went away recently, probably with my upgrading to v14.
          I tried the DSP and it didn't work, even when enabling all the CPUs.
          Any thoughts?
            dBpoweramp Configuration will tell you what version you have.
            • JoeBroesel
              • 36
              installing only the batch converter:
              Linn Klimax DS --> Accuphase CX260 --> BM35
              • Jeffy912
                • Nov 2008
                Hey,
                Here's a screenshot of my config screen. I'm pretty sure it's the registered version. I paid for it and still have my retrieval key. Also, like I said, the multi-core used to work.
                Do I now have to enable it somewhere?
                • JoeBroesel
                  • 36
                  where it says "Registered Power Pack", my version tells me "Registered Reference".
                  Rainer
                    See:
                    • Jeffy912
                      • Nov 2008
                      Hey guys,
                      Thank you all for clarifying that. I guess I just confused "Registered" with "Reference." Maybe it should've been obvious, but I guess I have to pony up to the Reference version.
                      Although, that doesn't explain why multi-core used to work for me. Is this a feature that was recently moved to the Reference version?
                        No, has always been in the Reference version, perhaps you installed a version where the 1 month Reference trial was activated.
