Multi Encoder Problems when batch ripping to multi formats
  • Riptide
    • Jul 2010
    • 9
    I using the batch converter to rip a flac file to Mp3/320 ,V0, V2,Ogg 0.8 and 320 AAC.
    I choose the multi encoder but It doesn't give me album, year, song and format as I set it to do. I have close to 200 flac albums to rip to these 5 formats and I don't want to do them seperately. I keep having to cancel . As soon as I press convert I keep a eye on the destination so I see that its not doing it right. Pulling my hair out. where am I going wrong. I have the latest version. and all the codec works if I rip one by one.
    Help guys.
    • 46044
    Re: Multi Encoder Problems when batch ripping to multi formats
    on each encoder you add to multi encoder you must set the output folder and select dynamic if you want the create sub folders (of album etc).
    • Riptide
      • Jul 2010
      • 9
      Thanks for your quick reply but I'm sure I've already done this. These pics might explain my setting better so you can see if I'm doing something wrong. I make sure each encoder save to the folder I want and dynamic is selected. Please let me know what you think.
      The last image is the setting I have for each encoder.
        • 46044
        I would need to see a picture of the encoder settings page (within multi-encoder).
        • Riptide
          • Jul 2010
          • 9
          What do u mean by that spoon. How do i get within multi-encoder?
            • 46044
            It suggests you source files have no ID Tags, they are wave files created by EAC?
            • Riptide
              • Jul 2010
              • 9
              Here is one of the album I'm trying to convert. They all say flac. They play as flac and eac is configure to rip to flac.
              Spoon this is a flac file for sure and it has tags as well.
              Windows properties pic.
                • 46044
                The last image does not exclusively show ID tags, right click on the flac file >> Edit ID Tags, that will show if there are tags present.
                • Riptide
                  • Jul 2010
                  • 9
                  Here is a pic of a flac file I edit.
                  I'm gonna try and rip a flac file I downloaded to make sure my EAC is configured k.
                  • Riptide
                    • Jul 2010
                    • 9
                    I tried another flac file I got from somewhere else and all work well. Spoon do know how I make sure id tags are in my rips?
                    • Riptide
                      • Jul 2010
                      • 9
                      All is working well. Eac just wasn't configured well. Really making life better.
