dMC doesn't write tags on OGG conversion
  • LunaticWolf
    • Jun 2010
    • 9
    Running Windows 7 x64, R13.5
    When converting any file to Ogg Vorbis, dMC doesn't seem to write any tags the previous file had. I have tried converting from FLAC, other MP3s, and still the same result.
    If I right click on the the ogg, and click edit tag, it shows that there are no ID tags in the file. If I import the file into Winamp, they have no tags.
    .MP3 files write tags just fine. I have tried both the original Ogg Vorbis codec and the Lancer version, neither work. Both codecs are the latest versions.
    Any help here?
    Re: dMC doesn't write tags on OGG conversion
    Look in dBpoweramp Configuration >> Codecs does it list ogg in the decoders?
    • LunaticWolf
      • Jun 2010
      • 9
      Yes, It does list "Ogg Vorbis Decoder" under decoders
        Right click on an Ogg >> Edit ID Tag and try adding a tag manually, does it work?
        • LunaticWolf
          • Jun 2010
          • 9
          I entered in a couple of the fields, and clicked OK.
          Upon right clicking and clicking edit tag again, It shows that there are no tags. Importing into Winamp shows no tags on the file I attempted to add them to.
          I should also note that I didn't have this issue until I upgraded to Win 7 64 bit from Vista 32 bit.
            Try uninstaling dbpoweramp, reboot Windows then reinstall. Your upgrade from 32 bit to 64 bit would not update dbpoweramp which needs resintalling.
            • LunaticWolf
              • Jun 2010
              • 9
              Unneccesary. I did not do an upgrade. I wiped the hard drive and did a fresh install of windows. Dbpoweramp was installed on the 64bit os.
                In that case try R14:
                • LunaticWolf
                  • Jun 2010
                  • 9
                  The same issue is still present with R14.
                  Converting to ogg results in the converted file having no tags. Converting to MP3 file correctly writes the tags.
                  • LunaticWolf
                    • Jun 2010
                    • 9
                    I found an old 12.3 release on one of my hard drives, and thought, what the heck.
                    The 12.3 release correctly wrote the tags when converting to ogg.
                    There must have been some sort of change in the code between 12.3 and 13.4 to cause this to occur on 64 bit systems.
