Gonverting 96kHz/24bit flac to 44.1/16bit flac
  • evanb
    • May 2010
    I have downloaded some albums in 96kHz/24bit and also 192khz/24bit flac format. Is it possible to convert these files to 44.1khz/16bit using dMC. At this stage I have no way of playing these via my SONOS so as a temporary measure would like to convert them. I have managed to alter the bit rate with no problem using DSP effects but when I try the resample setting it reduces the file to silence and only a few Kb in size. I have tried converting the flac to wav first but still no joy.
    Thankyou
    • 45857
    Re: Gonverting 96kHz/24bit flac to 44.1/16bit flac
    Make sure you are using R13.5 and the latest R6 DSP effects (as there were fixes in this area).
    • evanb
      • May 2010
      Thanks Spoon. Works well now. A quick query. When converting 96/24 Flac files using DSP effects to 44.1/16 is it better to convert the original FLAC to WAV first, use DSP then convert back to FLAC or doesn't it matter?
      Thanks again
        • 45857
        Does not make any difference.
