Arrange Audio Problem
  • mutepost
    • Mar 2010
    I am having a problem using the [IFMULTI]string[] element of the batch converter when using the Arrange Audio plugin. I have a folder containing a number of tracks from a two disk album and have checked that the disc property is set to 1 or 2. When I run the Arrange Audio converter it seems to ignore the IFMULTI statement completely.
    I am using the following statement: -
    complete\[album][IFMULTI] - Disc [disc][]\[track] - [title]
    After I have run the Arrange Audio the files are correctly renamed and moved to the completed folder but under a single folder with just the Album name.
    I am using the reference version 13.4 and Arrange Audio version 3.0. Has anybody else had this problem or am I using the statement incorrectly.
    Any help much appreciated.
    Simon
    Re: Arrange Audio Problem
    The disc should be set to 2/2 or 1/2
    • mutepost
      • Mar 2010
      Ahhhh..
      Thanks for the help Spoon - I amended the disc property and everything is now working as it should.
      Simon
