Problem with OGGvorbis
  • hamsen
    • Dec 2009
    • 21
    I have 2 problems concerning OGGvorbis:
    1) RightClick ogg-file, edit tag, add albumart.
    The image selected is accepted, but it's never written to the file.
    2) Having an OGG-file with an authorized cover (Metablock_Picture) and then running DSP-Replaygain, the following happens:
    The ReplayGain tags (4) are placed behind the coverart, which is correct.
    The problem is, that the file is rewritten in UTF8, which corrupts the actual length of the image. (LengthField does not correspond to the actual length).
    Regards
    Thomas
    Regards
    Thomas
  • hamsen
    • Dec 2009
    • 21
    Re: Problem with OGGvorbis
    Addendum to the post:
    If the file contains an unauthorized picture (COVERART Base64 coded) the file is also corrupted.
    Regards
    Thomas
    Regards
    Thomas
    • hamsen
      • Dec 2009
      • 21
      Is this post being ignored :(
      or am I too impatient?:vmad:
      Regards
      Thomas
        Potential bug noted (it will be a while before we are in the area of the Ogg codec again). When you say corrupted, can dBpoweramp read the tag afterwards?
        • hamsen
          • Dec 2009
          • 21
          No!
          Regards
          Thomas
