Power Pack Problems
  • aneesheewah
    • Mar 2003
    • 9
    Power Pack Problems
    :headbang:
    I have installed dbpowerAMP Converter, dMC Power Pack, the WMA V8 and Real Audio (Encoder and Decoder) Codec to my computer, and here is the problem.
    Whenever I want to use the Power Pack's features (i.e. Vocals Out, Add Silence, etc.), the little rocket doesn't appear in the little area it supposed to be in. Now, the Power Pack has only worked 2 times on my computer, the first time I installed it, and the time right before now.
    I understand that not being registered, which I'm not registered, means the dMC Power Pack will expire. So, what I do is reinstall it.
    Tell me what is the problem... It's give me a headache!
    :headbang:
  • Razgo
    • 2532
    when i right click over a file and select convert to and i want to use the powerpack DSP features like Vocals Out, Add Silence, I press the "Power Pack DSP" "button" not the Power Pack "Rocket".
    is this what you mean?
    • aneesheewah
      • Mar 2003
      • 9
      Yes, but the button isn't there either.
        • 46167
        Its trial would have expired.
        • aneesheewah
          • Mar 2003
          • 9
          I understand that.
          But then how come of all the times I downloaded it, the first time, and the time I downloaded it a couple weeks ago worked?
          It's puzzling, and VERY annoying
          • MP3 Fan
            Power Pack Expiration
            Just purchase it. It's well worth it. Simply uninstalling and re-installing a program will not regain the 30 day trial period. There's a bit more to it than that.
            I reccommend purchasing the product. The programmer deserves a reward for his effort, and is already supplying a wonderful program for free.
