Problem with utility codec
  • hamsen
    • Dec 2009
    • 21
    I have installed most of the utility codecs.
    If I want to use AudioDetails, I can select it in the drop down list.
    If I want to calculate and add ReplayGain tags, I can't see the ReplayGain utility codec in the drop down list.
    Why?
    I just want to add tags to an existing file.
    PS: Could you give me a hint as to where in the m4a-file I can see if it is a ALAC encoded file? Is it in an atom or...?
    Regards
    Thomas
    • 6189
    Re: Problem with utility codec
    to add replaygain tags to the file you select "convert" but instead of selecting a codec (like FLAC or mp3lame) you select REPLAYGAIN. This will scan the files and add the replaygain tags.
    p.s. i assume you have the replaygain codec installed.
    • hamsen
      • Dec 2009
      • 21
      Well, that's my problem.
      I think I have it installed.
      At least I can use replaygain in DSP effects.
      Regards
      Thomas
        • 6189
        I'm not sure I completely follow you here. The ONLY place to use replaygain is as a DSP effect. You set it as a DSP effect when ripping or when converting. And if you already have the files, you "convert to" the DSP effect. Your comment seems to imply that you're missing some option to use replaygain. Don't let the "convert to" or the label "dsp" throw you. It is not re-converting the audio or adding any DSP effects to the audio itself. The replaygain DSP is merely adding tags. Sorry if I misunderstood your comment above....just wanted to be clear.
        • hamsen
          • Dec 2009
          • 21
          Yep, that's it.
          I'm missing the replaygain option in "ConvertTo".
          Also there is no replaygain dll in the folder encoders.
          Anybody knows what's wrong?
          Regards
          Thomas
            • 46228
            Install it from Codec Central (utility codecs near the bottom)
            • hamsen
              • Dec 2009
              • 21
              Thanks, Spoon.
              I'm pretty sure I did this before.
              Anyway, it's working now.
              Regards
              Thomas
                • 46228
                You want to write your own program to detect ALAC? it is complex, yes in one of the sub atoms (the structure is dependant on format), but there is an ALAC identifier
                • hamsen
                  • Dec 2009
                  • 21
                  Hi Spoon
                  I already have an AudioPlayer that plays mp4/m4a + m4a (alac).
                  What I need is to figure out which type because I need to select the appropiate dll (BASS).
                  I already access the file reading atoms, but I can't find the exact specs for the alac atom.
                  Is it safe to assume, that the file is encoded in ALAC, if the alac atom(s) exists?
                  Regards
                  Thomas
