HD wave to flac conversion does not work
  • 4Thomas
    • Jul 2009
    Hi all,
    I ripped/converted some tracks from a DVD-A to wave format. They play fine on the local computer using VLC but they would not play when streamed to a Linn DS. When I convert the wav to flac it does not play anymore (not even locally). Below is a description of the file using DMC[audio info]. Any idea how I convert such a file, so that a Linn DS would be able to play it.
    any help very much appreciated, thanks in advance,
    Thomas
    Audio Details for: F:\Music\JohnColtrane\track-01-02[1]-03-[L-R]-24-192000.wav
    Length: 7 minutes 8 seconds
    Channels: 2 (stereo)
    Sample Rate: 192 KHz
    Sample Size: 24 bit
    Bit Rate: 9'216 kbps (DVD)
    Audio Properties:
    Audio Quality: DVD (Lossless)
    Encoder Settings: PCM
    Wave Header: Wave Format Extensible
    Channel Mapping: Left, Right
    Sample Count: 82'262'240
    Riff Chunks: 'fmt ' 40 bytes, 'data' 470.71 MB
    Gapless: Yes
    ID Tags:
    _riff_1: DATA Length: 4 fmt
    _riff_2: DATA Length: 4 data
    • 46167
    Re: HD wave to flac conversion does not work
    It is the Extensible Header which I think the Linn cannot play, there is an option in dBpoweramp Configuration >> Codecs >> Advanced which can disable the writing of the extensible header.
    • 4Thomas
      • Jul 2009
      thanks Spoon, that solved the problem.
