mp3 to m4b tags problem (again)
  • skypilotpete
    • May 2009
    • 37
    I have recently had to completely uninstall dbpoweramp and reinstall. Now, when I convert mp3 files to m4b, the tags are not carried over to the m4b files. I had this problem once before, and it was solved (if I remember correctlly) by removing m4b from the directshow.txt file. I have tried this again, but it is not working. I have removed m4a and m4b from the directshow.txt file, rebooted my computer, but still no tags in the converted m4b files.
    Is there anything more I should be doing?
    I run Windows XP Pro SP3, dbpoweramp 13.3 Registered.
    Re: mp3 to m4b tags problem (again)
    make sure you have installed the m4a decoder
    • skypilotpete
      • May 2009
      • 37
      Thanks - that fixed it. I had only installed the m4b files, not the m4a ones.
