First Track Won't Rip
  • MasterOfPuppets
    • Nov 2002
    • 139
    All of a sudden I noticed that dMC would not rip my first track of any of my cd's. :confused: :confused: Well anyway, switching CDs didn't work, nor did reinstalling, nor did reinstalling different versions of dMC. The CDs play fine and rip fine on other rippers. I get the same message each time:
    Errors Whilst Converting:
    CODEC decompression error for '\\CdRom\Track01.cda'
    Unable to read CD, scratched disk?
    When I don't use CD Input then it gives me this one:
    CODEC decompression error for 'D:\Track01.cda'
    Nope, the CD is not scratched. I was thinking maybe something was stuck in the registry, but wasn't sure which folder to clear.
    Any ideas?
    Toute votre base sont appartiennent à nous!!!
    • 46228
    Try putting a spin up delay in.
    • MasterOfPuppets
      • Nov 2002
      • 139
      Nope, just tried it, but got the same result.
      If I start ripping at track two, then it works perfectly fine, so that rules out that.
        • 46228
        Have you recently set up accuraterip?
        • MasterOfPuppets
          • Nov 2002
          • 139
          Oh yea, forgot to mention that. I haven't ripped for a while, but the last time I remember it working was before I installed the AccurateRip database. Uninstalling it didn't do much, though.
            • 46228
            Install the 'Accurate Rip Test #3' version load Audio CD >> Options and press 'Reset' next to sample offset. (you have a drive that cannot read on sector before the track starts, but this is required for AccurateRip because your drive have a sample offset that direction).
