Ogg Vorbis Pentium 4 Encoder CLI problem
  • jwchess
    • Feb 2003
    • 9
    Hello,
    I have a problem with the Ogg Vorbis Pentium 4 Encoder CLI, I have a registered powerpack, but if I want to encode a track everything seems to go normal, but it doesn't really save them.
    All the files are saved but there all 0 kb.
    I attached one track as example.
    I've tried it at two computers with the same result.
    As far as I know, I don't do anything wrong because if I use the normal Ogg Vorbis encoder then everything goes fine.
    Normally I use the following settings: Quality 64 kbps, Stereo, 44100 Hz. I also tried other settings as well, but with the same results (all files are 0 kb).
    Can you please help me?
    Edit: Attachment didn't upload, maybe because it's 0 kb....
    Edit2: With debugging on I got the following message:
    "F:\Program Files\Illustrate\dBpowerAMP\Compression\Ogg Vorbis (CLI)\oggenc.exe"16 -as H:\~dmcin.wav -o H:\~dmcout.ogg -q 0 --resample 44100 -c -d 2002 -N 11 -t Save Me -l Timing is Everything ... -a Chris de Burgh -G Power Ballad
    • 46167
    If you have it in the debug mode and paste the command line into a dos prompt - what error does it show?
    • jwchess
      • Feb 2003
      • 9
      It shows the following message:
      '"F:\Program Files\Illustrate\dBpowerAMP\Compression\Ogg Vorbis (CLI)\oggenc.exe"16' is not recognized as an internal or external command, operable program or batch file.
      Edit:
      If I change it in:
      "F:\Program Files\Illustrate\dBpowerAMP\Compression\Ogg Vorbis (CLI)\oggenc.exe" 16 -as H:\~dmcin.wav -o H:\~dmcout.ogg -q 0 --resample 44100 -c -d 2002 -N 11 -t Save Me -l Timing is Everything ... -a Chris de Burgh -G Power Ballad
      (A space added between oggenc.exe" and 16)
      I get the following message:
      Warning: Illegal comment used ("-d"), ignoring.
      ERROR: Multiple input files with specified output filename: suggest using -n
        • 46167
        I think I have fixed it - save this file:
        To C:\Program Files\Illustrate\dBpowerAMP\Compression\Ogg Vorbis (CLI)
        overwriting the existing.
        • jwchess
          • Feb 2003
          • 9
          No, it's still 0 kb. :sad:
          And now I can't choose the settings for Quality, Mode and sample.
          (The bitrate etc.). :confused:
          The debug message is:
          So that doesn't seem right.
            • 46167
            Try this one:
            • jwchess
              • Feb 2003
              • 9
              Almost!
              But now oggenc.exe crashes everytime...
              When it's at 97% most of the time.
              But at least it does save the files now.
                • 46167
                Can you try it once more in the Debug mode - is it oggenc that is crashing or dMC when it picks up the encoded file?
                • jwchess
                  • Feb 2003
                  • 9
                  No it's oggenc.exe I think.
                  When I paste it in a dos-command, it runs till 99,9% and then I get a window with the message "oggenc.exe has encountered a problem and needs tot close. We are sorry for the inconvenience."
                  Details: "AppName: oggenc.exe AppVer: 0.0.0.0 ModName: oggenc.exe
                  ModVer: 0.0.0.0 Offset: 000022b9"
                  Dos window shows this:
                  Opening with wav module: WAV file reader
                  Encoding "H:\~dmcin.wav" to
                  "H:\~dmcout.ogg"
                  at quality 0,00
                  [ 99,9%] [ 0m00s remaining] -
                  Done encoding file "H:\~dmcout.ogg"
                  File length: 2m 47,0s
                  Elapsed time: 0m 19,0s
                  Rate: 8,8133
                  Average bitrate: 62,8 kb/s
                  Hope this helps....
                    • 46167
                    Please also post the Command that dMC asks for you to paste into dos.
                    • jwchess
                      • Feb 2003
                      • 9
                      Ok, sorry I forgot that one...
                      Here it is:
                      "F:\Program Files\Illustrate\dBpowerAMP\Compression\Ogg Vorbis (CLI)\oggenc.exe" -as H:\~dmcin.wav -o H:\~dmcout.ogg -q 0 --resample 44100
                        • 46167
                        Out of interest try a higher quality conversion, the line looks fine it is just the ogg encoder that is crashing an I am not able to help there. :(
                        • jwchess
                          • Feb 2003
                          • 9
                          You're right!
                          I tried it with other settings and then it doesn't crashes.
                          Now I use the following settings:
                          "F:\Program Files\Illustrate\dBpowerAMP\Compression\Ogg Vorbis (CLI)\oggenc.exe" -as H:\~dmcin.wav -o H:\~dmcout.ogg -q 0 --resample 48000
                          Wich is fine also.
                          Thank you very much for your help!
                            • 46167
                            What frequency were your original source files?
                            • jwchess
                              • Feb 2003
                              • 9
                              I don't know. How can I see that?
