Audio conversion engine overwrites destination file
  • peter_mc
    • Jul 2009
    • 24
    Sorry to bombard the boards but I am under some pressure to get this sorted and ACE looks like the perfect candidate if I can get it in and working properly!
    Anyway on to the problem. It does not seem to matter what the setting is, the destination file is overwritten.
    I tested this by processing two files, leaving the resulting files in the target folder, then processing the files again. I expected to see an error generated or the files to be present with a '1' added or similar.
    Instead the target folder had the same files. The date modified had been updated.
    • 46228
    Re: Audio conversion engine overwrites destination file
    It should be a matter of setting the ?overwrite files? option in the settings
    page. I will look into the problem and get back to you in the coming week.
    • daren
      • 153
      Hi Peter,
      The problem has been identified and fixed. A new version will be released in the next couple of days. I'll post to this thread when the new version is available for download.
      Best regards,
      Daren.
      TrinitySoftware
      • daren
        • 153
        Hi Peter,
        The problem has been fixed in version 4.05 of Audio Conversion Engine, which is now available for download (see http://www.dbpoweramp.com/ace_download.htm for the trial version).
        Best regards,
        Daren.
