Replaygain problem in v.13.3
  • damoresh
    • Jul 2009
    • 21
    I added the DSP effect Replaygain to my existing mp3 using the dmc 13.3 beta and after finishing i saw the values from the pop up it gave the values but after i clicked on the edit id tag it showed me replaygain_album_gain instead of Album Gain why is that so and it was same style of writing for other 3 is this a fault in new beta.
    Why did the underscore appear? Please help me i dont want this replaygain_album_gain instead i want Album Gain
    Re: Replaygain problem in v.13.3
    For mp3 replaygain_album_gain is the correct ID Tag to store album gain.
    • damoresh
      • Jul 2009
      • 21
      But it also comes the same for flac when i right click and click on the Edit ID tag it shows me the tag in which it is written as
      replaygain_track_gain -9.41dB
      replaygain_track_peak 1.309402
      Why is this not written as
      Track Gain -9.41dB
      Track Peak 1.309402
      Is there any way by which i can select only Track Gain and i don't want Track Peak like it is done in EAC.
        Peak is required for ReplayGain (the decoder can use it to make sure no clippig occurs).
        • damoresh
          • Jul 2009
          • 21
          Track Gain -9.41dB
          Track Peak 1.309402
            It is written like that because that is how the Replaygain standard requires tags to be written. If it was just "Track Gain" there was no guarantee that it wasn't gain from another program (such as iTunes) that would be incorrect for ReplayGain.
