Problems with perfect meta matches
  • trh22
    • Jan 2009
    I am loosing perfect meta match. it is completely greyed out and cant click it as an option. It seems to happen if I put a CD in, then if I take it out without ripping it and put it back in at a later time to rip it the perfect meta match is not highlighted and cant be viewed? Alt+M did not work either.
    Also I had a post maybe yesterday which maybe i forgot to hit submit or something but I cant find in the forum? What happened to Musicbrainz? It seems it is unavailable.
    thanks,
    Tim
    Re: Problems with perfect meta matches
    If it is taken from the cache then the 4 databases are not read, only the last fnal values. To get around this click the Meta button to reget the metadata.
    • trh22
      • Jan 2009
      thanks spoon,
      by the way, I on a different note but thought I would just ask here rather than create a new thread...
      I had read some time a go a nice explanation about how to interpret accurate rip results and it went through scenarios of what the different colored "x" and checkmarks mean as well as expnaining CRC and the number(in parenthesis) assigned to the rip and how they apply to the ripped track. I thought I read it here or possible a hydrogenaudio wiki, but I cant find it for the life of me. I wanted to pass it along to a friend. Do you know which I am talking about? if so thanks!
      Great program keep up the good work!
      Tim
        dBpoweramp Help File >> CD Ripper
