Convert header-less audio (.raw) to .wav
  • TomTom
    • Mar 2009
    Hi
    I have a project at work that requires us to batch convert a large number of header-less pcm (.raw) files ripped from our CDA archiives to .wav. The files are extracted with a .01, .02 etc. extension, depending on the number of audio tracks on a disc. The file extensions then need to be renamed to .raw for them to be recognised by other processing software.
    As our organisation has already purchased a copy of dbpoweramp Reference R 12.3 a while back for other conversion purposes, we would also like to use it for converting these files. The problem is that dbpoweramp does not recognise the .raw format. Is there a downloadable codec pack that will assist us in doing this?
    Thanks for any response.
    Tom
