Flac to WMA Lossless Results in Errors on Every Attempted track.
  • hshrader
    • Apr 2011
    Re: Flac to WMA Lossless Results in Errors on Every Attempted track.
    No DSP effects employed.
    Sorry on the confusion on the title of the post. Happy to start a new thread if you suggest.
      • 44073
      Email one of the FLAC files please:
      • NVman
        • Nov 2017
        Hello,
        I convert all my Flac files to wma so that I can stream from my OneDrive to Groove. Regularly I encounter some trouble converting High res flac (24 bits, 96 khz) to wma. But it works fine with most of the files...
        When I check the files with failed verification, I hear some scratches or I don't know how to name it, sometimes it is just one little noise on the whole piece. So it ruins everything...
        I tried to convert to Wav and it worked perfectly. When I converted to wma, same troubles with the same files.
        I am considering buying a Professional audio converter as I am desperate but maybe there is a solution... Isn't there?
          • 44073
          Use the DSP effects 'Resample' set to 44KHz and Bit depth, set to '16 bit' when converting to WMA.
